21588 Discussions
How change state Mealy machine
please helpme how change state Mealy machine because the default is moore in quartus.
in the state machine editor, right click on a state and choose properties. go to the actions tab and define an output port, value, and in the additional conditions column put the transition conditions for the output you are trying to generate.
as far as i can tell this should be the way to generate a Mealy machine.
Thanks thepancake
