21608 Discussions
How do I setup word sychronisation with Altera Soft LVDS with external PLL on MAX10
I successfully setup a SerDes link between two MAX10 devices with the soft LVDS IP and internal (!)
PLL. The devices are connected by two LVDS signals - one for clock and one for data.
SerDes factor is 1:10. Clock is 10MHz, bitrate is 100Mbit/s.
Now I need to modify the design to use the SerDes IP with an _external_ PLL. I modified the IP with the mega wizard
and switched on "use external PLL". The component now looks like this:
component lvds_rx_extpll is
port (
rx_inclock : in std_logic := 'X'; -- rx_inclock
rx_in : in std_logic := 'X'; -- rx_in
rx_out : out std_logic_vector(9 downto 0) -- rx_out
end component lvds_rx_extpll;
In general the design works fine. But how is the word synchronisation done in this case? With internal PLL the rx_out data
is sychronized to the edge of the 10MHz signal. But with external PLL the IP has no chance to do so, because it only gets the 100MHz clock
from the PLL (rx_inclock).
How do I implement the SerDes receiver with external PLL that behaves identical to the receiver with internal PLL? Do I have to use the bitslip function by hand?
Or how can I bring the 10MHz clock into the game?
So here is my (ext.) PLL:
component serdes_pll
PORT (
areset : IN STD_LOGIC := '0';
inclk0 : IN STD_LOGIC := '0'; -- 10MHz coming from transmitter
c0 : OUT STD_LOGIC ; -- 100MHz -> rx_inclock
c1 : OUT STD_LOGIC ; -- 10MHz
locked : OUT STD_LOGIC
end component;
This is my previous working receiver with internal PLL with rx_out vector beeing valid on rx_outclock:
-- serdes receiver with internal PLL
component lvds_rx is
port (
pll_areset : in std_logic;
rx_inclock : in std_logic; -- 10MHz from transmitter
rx_in : in std_logic; -- data from transmitter
rx_out : out std_logic_vector(9 downto 0); -- deserialized word
rx_outclock : out std_logic; -- 10Mhz clock for rx_out
rx_locked : out std_logic
end component;
Matthias
Search around for "altlvds align" and you'll find several threads here and elsewhere talking about the issue of aligning data coming out of the ALTLVDS_RX.
Long story short, you feed the RX path a known pattern and jog the 'align' bit to shift the word until it matches the pattern you expect.
In your case, you probably want to supply ALTLVDS_RX with your 10MHz clock as an additional 'rx_in' to key off as a framing signal.
