21615 Discussions
How many clock cycle latency for 32 bit Integer Multiplication in Altera Stratix V?
Hi
Since I am developing a hardware in verilog for high frequency application using Altera Stratix FPGA, and involves 32 bit integer multiplication. The application that I am designing needs the result of the multiplication in one clock cycle.
Question: Will I get the resultant product in one clock cycle?
I referred the Stratix V handbook and it says that a DSP module can handle
: One 27*27 multiplication
: Two 18*18 multiplication
: Three 9*9 multiplication
So from the above information, two 2 DSP blocks are required for parallel multiplication and subsequent summing up. But can this be done in a clock cycle
in Stratix V(Assuming that I am working at 100 - 200 MHz internal clock)
Thanks in advance
Jeebu Jacob Thomas
Stratix V has support for one independent 32x32 multiplication using 2 cascaded DSP blocks (internally routed). Should be able to achieve 200MHz easily for one clock cycle operation.
https://www.altera.com/products/fpga/features/dsp/stratix-v-dsp-block.html
Why not write some proof of concept code and run it through timequest?
--- Quote Start ---
--- Quote End ---
Hi Tricky,
Thanks for the quick reply. We dont have a quartus tool to check through timequest yet. Quartus Evaluation version wont support Stratix V. We have just given order for buying the same.
Thanks again
Cheers
Jeebu
Thanks a lot mikedsouze.
Cheers
Jeebu
