21611 Discussions
How read data file in a testbench
Hi all:
Im trying to do my testbench, i want read the inputs from a .txt file and write the outputs to a .txt file
library IEEE;
use ieee.std_logic_1164.all;
use ieee.std_logic_textio.all;
entity testUnidadALULog is
end;
architecture test of testUnidadALULog is
COMPONENT UnidadALULog is
port(
DatoA : in std_logic_vector (31 downto 0);
DatoB : in std_logic_vector (31 downto 0);
Operacion : in std_logic; --- 1 para Mulltiplicacion 0 para Division
AUXDATO_A, AUXDATO_B : out std_logic_vector (35 downto 0);
AUXSUMA : out std_logic_vector (36 downto 0);
AUXRESTA : out std_logic_vector (36 downto 0);
AUXselector: out std_logic_vector (36 downto 0);
Resultado_Entero : out std_logic_vector (63 downto 0)
end component;
signal PruDatoA, PruDatoB : std_logic_vector (31 downto 0);
signal PruOperacion : std_logic;
signal PruAUXDATO_A, PruAUXDATO_B: std_logic_vector (35 downto 0);
signal PruAUXSUMA, PruAUXRESTA: std_logic_vector (36 downto 0);
signal PruAUXselector: std_logic_vector (36 downto 0);
signal PruResultado_Entero: std_logic_vector (63 downto 0);
begin
Pruebas : UnidadALULog port map
DatoA => PruDatoA,
DatoB => PruDatoB,
Operacion => PruOperacion,
AUXDATO_A => PruAUXDATO_A,
AUXDATO_B => PruAUXDATO_B,
AUXSUMA => PruAUXSUMA,
AUXRESTA => PruAUXRESTA,
AUXselector => PruAUXselector,
Resultado_Entero => PruResultado_Entero
verificar : process
file datosin: TEXT open read_mode is "pruebasin.txt";
file datosout: TEXT open write_mode is "pruebasout.txt";
variable linea: line;
variable vDatoA, vDatoB :std_logic_vector(31 DOWNTO 0);
variable vOperacion: std_logic;
begin
while not endfile(datosin) loop
readline(datosin,linea);
read(linea,vDatoA);
read(linea,vDatoB);
read(linea,vOperacion);
PruDatoA <= vDatoA;
PruDatoB <= vDatoB;
PruOperacio <= vOperacion;
wait for 200 ns;
write(linea,PruAUXDATO_A);
write(linea, string'(" "));
write(linea,PruAUXSUMA);
write(linea,PruAUXRESTA);
write(linea,PruAUXselector);
write(linea,PruResultado_Entero);
writeline(datosout,linea);
wait for 350 ns;
end loop;
wait;
end process verificar;
end test;
but when I comile testUnidadALULog.vhd in ModelSim program I have 2 Errors
# Unknown identifier text.
# File declaration must have a subtype indication that is a file type
do you know how what I have to do???
Thanks!!!!!!!!!!!!!!!1
you need to include the library std.textio.all aswell. std_logic_textio is just to get the std_logic/std_logic_vector write functions. functions for string, integer, bit (ie all the base types) are in the std.textio package. It also contains the text file type.
