21602 Discussions
How to Infer a ROM's Contents from a file?
ALane
I'm trying to convert a Xilinx design onto a Cyclone V and am struggling with the Intel documentation on how to infer a ROM where its contents are provided by an external mif file​. Looking at the documentation this idea does not seem to be covered. (i.e. the examples all appear to generate the ROM contents within the hdl files)
Here is a snippet from the code I am trying to re-use:
impure function init_mem(mif_file_name : in string) return T_ROM_TYPE is
   file mif_file  : text open read_mode is mif_file_name;
   variable mif_line : line;
   variable temp_bv : std_logic_vector(G_DATA_WIDTH-1 downto 0);
   variable temp_mem : T_ROM_TYPE;
begin
   for i in T_ROM_TYPE'range loop
       readline(mif_file, mif_line);
       hread(mif_line, temp_bv);
       temp_mem(i) := temp_bv;
   end loop;
   return temp_mem;
end function;
-- ROM array constant
constant rom : T_ROM_TYPE := init_mem(G_ROM_INIT_DATA);
begin
-- ROM read access control
rom_cotrol_proc : process (CLK)
  variable address : integer range 0 to ((2**G_ADDR_WIDTH)-1);
   begin
  if CLK'event and CLK = '1' then
   if IP_EN = '1' then
   address := to_integer(unsigned(IP_ADDR((G_ADDR_WIDTH-1) downto 0)));
   OP_DATA <= rom(address);
   end if;
  end if;
   end process;
Abe
Valued Contributor II
You could initialize the memory using MIF file or Intel HEX file. I would suggest you replace your ROM code with one of Intel's 1-port ROM Megafunctions. When you use the megafunctions, there's an option to initialize the memory using MIF or HEX files.
Migrating the small ROM/RAMs to using Intel megafunctions may help resolving such issues.
-Abraham
Tricky
New Contributor II
Unfortunately, Quartus has been lacking the ability to infer the ram contents using textio for years - I raised an enhancement request on this 10 years ago - afaik this is still not possible!!!!
You can use the  ram_init_file  attribute to read the contents of a .mif file during synthesis, but it wont load it during simulation. The only way to load it during simulation is with an init function (like the one you posted - but this only would need to be removed from synthesis) or by using the altsyncram megafunction and specifying an init_file generic to the .mif file
Abe
-Abraham
ALane
Thanks for the answers!
Looks like I'll try the mega function where I can at least setup the ROM dimensions/contents via generics.
