21592 Discussions
How to access FPGA Manager's Input & Output ?
I am using Cyclone V SoC Dev Kit.
I want to write a bare-metal program to access PUSH_BUTTON & DIP SWITCH on the board.
I check the schematic of EVK, BUTTON & DIPSW is connect to FPGA manager's Input port.
I have write a code as below, but can't read the input data from FPGA manager. How to make it available to access FPGA manager's Input ?
----------- Bare-metal source code -------------
// Download SOF before running program !!!
int main(int argc, char** argv)
ALT_STATUS_CODE status = ALT_E_SUCCESS;
ALT_FPGA_CFG_MODE_t mode;
status = alt_fpga_init();
if(status != ALT_E_SUCCESS)
return 1;
if (alt_fpga_state_get() != ALT_FPGA_STATE_USER_MODE)
printf("\n not in USER_MODE. \n");
return 1;
status = alt_fpga_control_enable();
return 1;
while(1)
uint32_t input = alt_fpga_gpi_read(0xFFFFFFFF);
printf(" input = 0x%X. \n", input);
return 0;
-------------- result ---------
intput val = 0xFFFFFFFF
Are you sure that in FPGA loaded .rbf or .sof with configuration, making routing to HPS of external pins ?
And similar program with HPS buttons work correctly ?
That's the point. I am not should that FPGA manager's input can directly connect to external pin.
What's the correct usage of FPGA input / output pins ?
I is the programmer, in principle circuit don't know !
May be method to insert your code in HWLIB-example, where LEDs was blinked -- there buttons MUST be available!
And then cut small portions of big code, try compile and run -- while buttons may work, else undo cutting, cut another lines... In that way you get minimal program and understand, what current is bad. While not finded good documentation :)
P.S. Try .svd files in debugger, as described in ug_soc_eds.pdf -- your code not need, and all GPIO may be visible after init.
Have you tried running that code with your finger on the button? Often board designs make push buttons active low so if you read 0xFFFF_FFFF when nothing is pushed and something like say 0xFFFF_FFFE when you push button 0 then it's behaving as I would expect with active low buttons.
Last but not least are you 100% sure those buttons and LEDs are connected to the FPGA manager GPIO and not just HPS GPIO? If the buttons/LEDs connect to FPGA I/O and are wired up to the HPS through the HPS Qsys component then yes, that's the FPGA manager GPIO you are using. If those buttons/LEDs connect to HPS I/O then you want to access the appropriate HPS GPIO component registers.
The Board has
1) 4 DIPSW for FPGA, 4 for HPS,
2) 4 PUSH_BUTTON for FPGA, and 2 PUSH_BUTTON for HPS
3) 4 LED for FPGA , 4 LED for HPS
The PUSH_BUTTON or LED or DIPSW connect to FPGA can access via LW_AXI_BRIDGE.
The LED of HPS is connect to GPIO 41~44, can access with GPIO registers of HPS.
I am sure the PushButton & DipSwitch is connect to HPS's PIN according to Cyclone V SoC Dev Kit (Rev.C) schematic. You can find in www.rocketboards.org (http://www.rocketboards.org). http://www.rocketboards.org/pub/documentation/alterasocdevelopmentboard/c5_soc_devkit_c.pdf?t=1365712679
- search keyword "USER_PB_HPS", on page 5
Is there any example source code to access FPGA Manager 's GPIO ?
https://www.alteraforum.com/forum/attachment.php?attachmentid=9117
I am totally wrong.
The PUSH_BUTTON & DIPSW is connect to GPIO2 (Input Only PINs), not FPGA manager .
Sorry for bothering everyone.
