Hi all,
We have an Agilex F-Series FPGA Dev Kit_Enpirion board
Can anyone provide the steps for autobooting the application in HPS?
Thanks & Regards
Raju S
raju1421, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
I just transferred your thread to the proper department. They will further assist you with your inquiries about this subject as soon as possible.
Albert R.
Hi Raju
We do not support baremetal application for the Agilex SOC.
However you could follow the Stratix10 guide from the HWLibs link here:
https://www.rocketboards.org/foswiki/Documentation/HWLib
REgards
Jingyang, Teh
Hi @JingyangTeh_Altera ,
Thanks for the response,
We are working with Linux OS not with bare metal.
We need to autoboot the application once mounting of rootfs.
Is there any script (or) steps to follow?
Thanks & Regards
Raju S
Hi AJ
You could refer to the link below for some examples:
https://theiotlearninginitiative.gitbook.io/embedded-linux/user-space/services
There are a few options available, you could try out the systemctl method.
Jingyang, Teh
Thanks for the response.
We will follow the steps mentioned in the link.
Thanks & Regards
Raju S
Hi Raju
Do you have any update on this case?
Did you manage to go through the material or any questions?
Jingyang, Teh
After going through the link also we are not able to do the changes in the mentioned files.
Suggest us any other method (or) ways?
Thanks & Regards
Raju S
Hi Raju
Apologies for the late response.
Are you in root privileges when u are working on the files?
Only root could make changes to these files.
Jingyang, Teh
Hi Raju
Any update on this case?
Are you able facing troubles after having root privilege?
Jingyang, Teh
We have tried with root user mode only.
But we are not able to solve the issue.
Raju S
Hi Raju
There are a few others way to auto start application.
https://www.baeldung.com/linux/run-script-on-startup
Could you share what error code you are looking at and what you have so far?
Jingyang, Teh
Hi Raju
Jingyang, Teh
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
