21615 Discussions
How to calculate the delay from flop to pin in FPGA with constraints?
SK_VA
I have set min and max delay constraints for an output pin wrt an input clock.
set_min_delay -from input_clock -to [get_ports {output_pin}] 4
set_max_delay -from input_clock -to [get_ports {output_pin}] 13
I am analyzing the clock to output delay of the pin in multicorner analysis to know the delay for this signal from the last flop to output pin.
It shows a variation from 5.4 ns to 12.4ns across PVT(Slow to Fast process). But when I try to measure the clock to output delay on board by probing the input clock and output pin for a rising edge I see only a delay approx 5ns.
So I am doubtful whether my timing analysis is wrong.
