Hello everybody!
I have 2 different quartus projects, one is for Nand flash controller and the other is for USB interface. I have to combine both of these so that I can use the USB interface to read data from and write data to the Nand flash. How should I do this. I am using quartus 10.1 and I have included components in both the projects using SOPC builder. Thanks in advance..Link Copied
I believe you cannot directly merge two Quartus projects. You might need to create a new project, then port over the IPs or instances required into the new project. You should consider if the size of FPGA as well.
--- Quote Start --- I believe you cannot directly merge two Quartus projects. You might need to create a new project, then port over the IPs or instances required into the new project. You should consider if the size of FPGA as well. --- Quote End --- Hey! Thank you bfkstimchan. If I create a new project, how should I combine the components which I have created separately for nand and usb interface? If I'm not creating a new project and wish to import files, then, Can I add the files of Nand project into the USB project using "add or remove files" option in project navigator? Else, can I write a top level and call both USB and the Nand flash files as components(port mapping)? These are just various ideas I have, I'm not sure it might work or not. Just asking your opinion. Any advice is welcome.. Also, what if I make the Nand Controller project as a custom component in SOPC and then add it into the usb's sopc?
you're probably better off starting a new project that includes all the files you need.
You'll need some form of top level linking them together - if they have the same interface spec then you can probably just connect them to each other, otherwise you'll need something (either code or QSys project) to connect them together.- Mark as New
Hey! I imported nand flash files to usb project using the "add or remove files" option in project navigator. I wrote a top level where I instantiated both nand and usb components.
It's working fine. Thank you very much to both of you for your time and advice...- Mark as New
You are welcome.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
