- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I am trying to figure out how to terminate unused GXB_TXp and GXB_TXn pins in an Arria V GX device.
Thanks, DanLien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dan -
Have you read the Arria V pin connection guidelines? https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/pcg-01013.pdf This is a very important document for all families. It says to leave all unused GXB_TX pins floating. No need to terminate. Bob- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Dan - Have you read the Arria V pin connection guidelines? https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/pcg-01013.pdf This is a very important document for all families. It says to leave all unused GXB_TX pins floating. No need to terminate. Bob --- Quote End --- Thank you for the response. Yes, I did read that document. It says "Leave all unused GXB_TXp pins floating", which seems to inply to float just the "p" pins. Hence my confusion. Dan
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- Thank you for the response. Yes, I did read that document. It says "Leave all unused GXB_TXp pins floating", which seems to inply to float just the "p" pins. Hence my confusion. Dan --- Quote End --- I see what you mean. It's a typo. Leave both pins floating. You should let Altera know about this. Check the PCG for Cyclone V, Arria 10, etc. They correctly say to leave both pins floating. Bob
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
