21611 Discussions
How to connect unused GXB_TX pins in an ARRIA GX device
I am trying to figure out how to terminate unused GXB_TXp and GXB_TXn pins in an Arria V GX device.
Dan
Dan -
Have you read the Arria V pin connection guidelines?
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/pcg-01013.pdf
This is a very important document for all families. It says to leave all unused GXB_TX pins floating. No need to terminate.
Bob
--- Quote Start ---
Dan -
Bob
--- Quote End ---
Thank you for the response.
Yes, I did read that document.
It says "Leave all unused GXB_TXp pins floating", which seems to inply to float just the "p" pins.
Hence my confusion.
Dan
--- Quote Start ---
Hence my confusion.
Dan
--- Quote End ---
I see what you mean. It's a typo. Leave both pins floating. You should let Altera know about this. Check the PCG for Cyclone V, Arria 10, etc. They correctly say to leave both pins floating.
Bob
