20789 Discussions
How to create sine and cos waves of different frequencies using Cyclone III(VHDL)
Is there anyone can help me to deal with one problem: How to create sine or cos waves in Cyclone III FPGA in VHDL. I have no clear idea to program the VHDL code although I have search some documents.
I will be much appreciate if someone can help me out.
Thank you very much.
Best wishes,
peipei
If you have no VHDL knowledge, my first suggestion would be to find a good tutorial and get yourself familiar with the language.
As for the sin waves, sine and cosine are identical, but with a phase shift. It would be easy enough to build a ROM of sin values in VHDL and just read them out.
Or read up on Goertzel.
There are many methods that can be used, A simple lookup table is the easiest, then just step through the lookup table at different rates.
If you truly want to generate Sin and Cos values, a CORDIC algorithm is the way to go.
Pete
If it was me I will use the altera ip away from manual hdl coding. I think cordic is too much for a beginner to hand code or understand.
--- Quote Start ---
--- Quote End ---
Does altera provide cordic IP for user now?
Hi Tricky,
I have learnt VHDL and I suppose I have some knowledge of this language.
But just for this application, I have not clear idea to achieve this.
In my mind, I want to use Look up table, due to the ADA board is 14 bits, and I have generated the different values in Excel for one cycle, I am not sure should I generate all 2^14 values or not.
Thanks for your reply.
Best wishes,
peipei
--- Quote Start ---
--- Quote End ---
Hi Jerry,
I am planning to use LUT.
Do you have specific suggestions? My ADA board is 14 bits.
Best wishes,
peipei
--- Quote Start ---
--- Quote End ---
Remember Sin and cosine are reflective, so you only need 2^13 values in the rom, you use the 14th bit as the sign bit.
CORDIC is suitable for generating the sin/cos of an angle.
You can generate sin(a + delta) from sin(a - delta) and sin(a) with a single multiply (and a shift).
The only slight problen is that the amplitude can drift.
