- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
How to determine the pins of seriallite protocol used in arria II GX devices
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
As I understand it, you have some inquiries related to the SerialLite protocol used in Arria II GX devices. I believe you are referring to the SerialLite II IP. Would you mind to further elaborate on your inquiries ie if you encounter any problem fitting the IP in the device?
If you do not have pre-defined pin placement yet, you can let Fitter perform the auto-placement of the pins according to your design. Fitter will help to check against all the internal placement rules to ensure optimal placement.
Please let me know if there is any concern. Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello!
Thank you very much.
Your reply helped me a lot.
If I encounter problems again, I will seek your help as soon as possible.
Once again, my sincere thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks for your update. You are welcome.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
My friend, I have a new problem
In the arria II GX device, I use a 0.9V power supply to power the VCC, but the maximum current supported by the power supply is only 300mA. I want to know whether this current can satisfy the chip's work? If not, how much current does the power supply need to output to meet the working requirements.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
