21615 Discussions
How to generate clock in altera ep2c5t144c8 board?
Hi!
I am facing problem for generating clock in ep2c5t144c8 board of altera quartus II.
I have tried many times to set the clk in time quest analyses but it is not
giving any response when I check my desired signal on oscilloscope!
I have attached the screen shots of 'create clock' and 'name finder' windows.
everyones response will be highly appreciable!
Thank you!
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; library STD; use STD.TEXTIO.all; --use ieee.std_logic_arith.all; entity pwncheck is port ( clk : in std_logic; reset : in std_logic; led : out std_logic); end pwncheck; architecture operation of pwncheck is signal count_pwm_freq : unsigned(11 downto 0); signal set_pwm_duty : unsigned(11 downto 0); signal freq_pwm_maint : unsigned (11 downto 0); begin process(clk,reset) begin if (clk'event and clk = '1')then count_pwm_freq <= count_pwm_freq + 1; --"010011100010" ;--010011100010=>1250 if (count_pwm_freq = 010011100010)then led <='0'; else if (count_pwm_freq = "100111000100")then --100111000100=>2500 count_pwm_freq <= (others => '0'); led <='1'; end if; end if; end if; --clock end process; end operation;
Change if (count_pwm_freq = 010011100010)then
to if (count_pwm_freq = "010011100010")then
Cheers,
Alex
