21615 Discussions
How to instantiate my SOPC hardware
i'm all new at FPGAs, it's only been a few days since i'm working on it so i started reading some tutorials.
I successfully managed to light on a led by using a switch thanks to the tutorial named "Introduction to the Altera SOPC Builder Using Verilog Design". So i wanted to start something a little bit more complicated.
I created a new Quartus II project named "project7". Then, i used SOPC Builder to create my hardware, however i really don't know how to instantiate it using verilog.
I tried to adapt the file "nios_system_inst.v" from my previous project which was :
// Implements a simple Nios II system for the DE2 board. // Inputs: SW7−0 are parallel port inputs to the Nios II system // CLOCK_50 is the system clock // KEY0 is the active-low system reset // Outputs: LEDG7−0 are parallel port outputs from the Nios II system module lights (SW, KEY, CLOCK_50, LEDG); input SW; input KEY; input CLOCK_50; output LEDG; // Instantiate the Nios II system module generated by the SOPC Builder: // nios_system (clk, reset_n, out_port_from_the_LEDs, in_port_to_the_Switches) nios_system NiosII (CLOCK_50, KEY, LEDG, SW); endmodule
The file that i wrote is the following :
module nios_system0 ( // 1) global signals: CLOCK_50, KEY, // the_hex0 HEX0, // the_hex1 HEX1, // the_hex2 HEX2, // the_hex3 HEX3, // the_lcd LCD_EN, LCD_RS, LCD_RW, LCD_DATA, // the_leds LEDG, // the_switches SW ) ; input CLOCK_50; input KEY; output HEX0; output HEX1; output HEX2; output HEX3; output LCD_EN; output LCD_RS; output LCD_RW; inout LCD_DATA; output LEDG; input SW; nios_system NiosII (CLOCK_50, KEY, HEX0, HEX1, HEX2, HEX3, LCD_EN, LCD_RS, LCD_RW, LCD_DATA, LEDG, SW); endmodule
However it does not work. Indeed, when i check the pin assignments, i realize that almost none of the pins has been "connected" (because there is a question mark in front of the pin names).
I know that i'm not really clear about what i'm saying but i'm all new at FPGAs so it is still a little bit complicated for me :D
Some information :
I am using a DE2 board with Quartus II 9.0 (web edition)
Thank you in advance
Try this tutorial:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
There's a DE2 example in there.
Cheers,
Dave
