21602 Discussions
How to manually trigger or inhibit periodic OCT updates in Arria 10
SLabe
Partner
As mentioned in A10 EMIF UG, looking for information on the following statement:
"Contact Intel FPGA Technical Services for information on how to manually trigger or inhibit periodic OCT updates for applications that are sensitive to latency."
Please share the solution so I can enable my customer. Thank you,
yoichiK_intel
Hi
You can change the periodic OCT option in the EMIF IP GUI parameter. 
SLabe
Partner
Hi, the GUI only lets permanently enable or disable Periodic OCT Calibration. What we need is the ability to selectively block it during critical data transfers and then re-enable it the rest of the time to compensate for temperature cycling, etc ...
According to 3.4.3:  https://www.intel.com/content/www/us/en/programmable/documentation/eqw1503946000045.html#mhi1460567996227 there is a way to do this, but requires your support. My local Intel resource indicated some lower level code may need changing to expose the appropriate controls.
Thank you,
yoichiK_intel
Hi
There is file to control the periodic OCT update and you can tweak the oct_recal_req signal in the file to enable or disable the periodic OCT.
ip/ed_synth/ed_synth_emif_0/altera_emif_arch_nf_191/synth/altera_emif_arch_nf_oct.sv
Ben_C
Hi
Are you sure it's  oct_recal_req and not  oct_cal_req?
Maybe I'm wrong but oct_recal_req  output goes to c2t_afi[6] in altera_emif_arch_nf_seq_if.sv and that's it. No other action is done. On the other hand, the oct state machine triggers with oct_cal_req.
Thank you
yoichiK_intel
I was bit inaccurate.   not oct_cal_req ,but r_oct_cal_req signal in the RTL to disable it.   oct_cal_req is the signal used during the power up.
Here is the example RTL change to disable periodic OCT update.
    always_ff @(posedge w_oct_clock)
         begin
            if (w_oct_reset == 1'b1)
            begin
               r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1)]   <= 1'b0;
               r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-2):0] <= OCT_RECAL_TIMER_PRESET[(OCT_RECAL_TIMER_WIDTH-2):0];
               r_oct_recal_req                                <= 1'b0;
            end
                   else if (user_oct_disalbe)                                          // added, user interface signal.
                               r_oct_recal_req                                <= 1'b0; // added, disable periodic OCT
            else
            begin
               if (r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1)] == 1'b1)
               begin
                  r_oct_recal_req                                <= ~r_oct_recal_req;
               end
               else
               begin
                  r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1):0] <= r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1):0]
        - {{(OCT_RECAL_TIMER_WIDTH-1){1'b0}}, 1'b1};
               end
            end
         end
