- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I have designed a mux in Cyclone IV-E device. I need to meet the Pin to Pin delay constraint of 10 ns. Tools used are Quartus II 14.0 and Timequest. I am geting data path with delay of 13.309ns...IC delay of this path is found to be ~7.5ns:(:confused: Part of report is added below. Slack From Node To Node Launch Clock Latch Clock Relationship Clock Skew Data Delay -3.309 unc_jtag_tdi tdi_unc2 n/a n/a 10 0 13.309 Is it possible to reduce this delay? The logic implemented is a combo mux! I have even tried a direct pin to pin mapping wihout any logic...and data delay is 7.496 for that(IC Delay is 3.640ns)!! Thanks, Neeraj G N- Balises:
- SDC
Lien copié
3 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Why do launch and latch clocks say n/a?
Can you post code and relevant SDC?- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi sstrell,
Thanks for your time. Launch and latch clock is not present because its an input to output data path. code is added below, all signals are I/O s. always @(jtag_mux_sel or unc_jtag_tdi or unc_jtag_trst_l or unc_jtag_tms or unc_jtag_tck or tdo_unc0 or tdo_unc1 or tdo_unc2 or tdo_unc3) begin case(jtag_mux_sel) 2'b00:begin unc_jtag_tdo = tdo_unc0; tdi_unc0 = unc_jtag_tdi; trst_l_unc0 = unc_jtag_trst_l; tms_unc0 = unc_jtag_tms; tck_unc0 = unc_jtag_tck; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b01:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; unc_jtag_tdo = tdo_unc1; tdi_unc1 = unc_jtag_tdi; trst_l_unc1 = unc_jtag_trst_l; tms_unc1 = unc_jtag_tms; tck_unc1 = unc_jtag_tck; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b10:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; unc_jtag_tdo = tdo_unc2; tdi_unc2 = unc_jtag_tdi; trst_l_unc2 = unc_jtag_trst_l; tms_unc2 = unc_jtag_tms; tck_unc2 = unc_jtag_tck; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end 2'b11:begin tdi_unc0 = 1'b0; trst_l_unc0 = 1'b0; tms_unc0 = 1'b0; tck_unc0 = 1'b0; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; unc_jtag_tdo = tdo_unc3; tdi_unc3 = unc_jtag_tdi; trst_l_unc3 = unc_jtag_trst_l; tms_unc3 = unc_jtag_tms; tck_unc3 = unc_jtag_tck; end default:begin unc_jtag_tdo = tdo_unc0; tdi_unc0 = unc_jtag_tdi; trst_l_unc0 = unc_jtag_trst_l; tms_unc0 = unc_jtag_tms; tck_unc0 = unc_jtag_tck; tdi_unc1 = 1'b0; trst_l_unc1 = 1'b0; tms_unc1 = 1'b0; tck_unc1 = 1'b0; tdi_unc2 = 1'b0; trst_l_unc2 = 1'b0; tms_unc2 = 1'b0; tck_unc2 = 1'b0; tdi_unc3 = 1'b0; trst_l_unc3 = 1'b0; tms_unc3 = 1'b0; tck_unc3 = 1'b0; end endcase end # ###SDC is added below#### set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 10.000 set_max_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 10.000 set_max_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 10.000 set_max_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 10.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tck}] -to [get_ports {tck_unc3}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tdi}] -to [get_ports {tdi_unc3}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc0}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc1}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc2}] 5.000 set_min_delay -from [get_ports {unc_jtag_tms}] -to [get_ports {tms_unc3}] 5.000 set_min_delay -from [get_ports {tdo_unc0}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc1}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc2}] -to [get_ports {unc_jtag_tdo}] 5.000 set_min_delay -from [get_ports {tdo_unc3}] -to [get_ports {unc_jtag_tdo}] 5.000 Thanks, Neeraj- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm pretty sure you'd need to constrain the two pins to a virtual clock, otherwise I don't think Quartus is actually going to treat that as a timed path.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
