21602 Discussions
How to set up Cyclon 10gx transceiver 10g base SR (Short Range 850nm MMF)/LR(Long Range 1310nmSMF )/ER?
syang97
  • I'm using the device of cyclon10gx, and I use the high-speed transceiver in it. My preset protocol is 10g base r..However, one of my clients USES an xilinx FPGA,We'll have optical communication
  • , and his 10G BASE R protocol needs to set up a 10G BASE SR or 10G BASE LR.
  • So,I want to know :
  • 1 ,can I set this in the high-speed transceiver of c10gx,How do I set up the correct docking?
2, Use the high-speed transceiver of c10gx to preset 10g base r. Should the single-mode(SM 850nm) optical module(SFP+) or multi-mode optical module be used?
THANK YOU!
This is my setup for the high speed transceiver using the C10 device
Deshi_Intel
HI,
Pls see my reply below.
  1. 10G BASE SR or 10G BASE LR setting in NativePHY
  • At the top of NativePHY IP gui, there is one section called "transceiver link type" where user can select either SR or LR option.
  1. Use the high-speed transceiver of c10gx to preset 10g base r. Should the single-mode(SM 850nm) optical module(SFP+) or multi-mode optical module be used?
dlim
syang97
  • 1 Thank you very much, I've noticed the options in the NATIVEPHY IP GUI called  "transceiver link type",But here's the explanation is RS :Chip to chip coummunication ;I don't know if this is the same as the" sr" in the 10gbase r protocol,
  • Now I know. Thank you very much
  • 2 My transceiver link type was selected as SR. I found in the actual test that both multi mode fiber and single mode fiber could receive data, but there was always a bit error rate, which may be caused by the incompatibility of the optical module I chose
  • 3 The XGMII interface data I receive sometimes has a bit of an order reversal, for example : The correct data should be :07060504_03020100; But sometimes the data I received was 03020100_07060504, and It's correct most of the time
  • Have you ever encountered a similar situation in this respect? Is it the same as the second problem? Is it caused by the incompatibility of the multi mode fiber I chose?
  • Thank you very much for your patience!
Deshi_Intel
HI,
The SR and LR in NativePHY IP basically means short range (chip to chip) setting and long range (chip to backplane) setting irrespective of protocol.
  • FPGA to SFP is consider as "chip to chip" connection
  • So, you should set it to SR for your case
Regarding BER error debug
  • Perhaps you can try enable PHY loopback to isolate is this board related issue or FPGA internal issue first
For the data swap issue and not data corruption issue
dlim
