21615 Discussions
How to use USB port on Stratix 3 ?
Hello guys,
I'm a beginner at using FPGA. I'd really appreciate it if someone could walk me through how to use the USB port of my Stratix III EP3SE260F1152CN.
Do I have to have access to IP license to use the USB port or can I just use it? There doesn't seem to be any tutorial on how to use the USB port.
I want to read image files from my USB Drive and display them on my monitor by hooking the FPGA board to a monitor. Any help is appreciated.
Thank you!
So FPGA's are programmable devices, so by default USB is not a function that is a hardcore, but something that can be added.
You are probably looking at a Development board with a USB port on it. So how you connect the USB is dependent on the board.
Check your schematic first.
If the board has a USB host capability, they usually have a demo project that uses it. It will use a licensed IP, but usually the Licensed IP will have a "Try it before you buy it" capability that will allow it to work either for a time limited time or if you have it hooked up to the active debugger. (Open cores plus licensing)
Pete
If you let me if you are using a Stratix III development kit, I can give some guidance on which reference or example design can satisfy your inquiry.
Thanks for the info anakha! :)
I am using a DE3 Stratix III board. Is it the same? Thank you so much! I really appreciate it!
You may refer to to DE3 user manual for more details on how to use the USB port in DE3 board
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=260&partno=4
