I would like to write into the SDRAM using Verilog. I am using DE2 board.
Please, need help.Link Copied
I want to make it clearer.
I need to write into the SDRAM using Verilog code without using NIOS. I am using DE2 board Cyclone II FPGA. Any help, please? Thanks- Mark as New
You can use SOPC Builder to add the SDRAM device, and then the product a system, there will be a description of SDRAM's. V paper, which is written using Verilog language.You can try it!
