21611 讨论
I am using an Arria 10 GX and cannot get any signals out of bank 2L, the 3V bank. I can move the signals to bank 2K at 1.8 V and they are fine. The VCCIO for bank 2L is at 2.98V on all three pins but the bank is acting as though it is not active while all
MBynu
初学者
971 次查看
of other bank are working fine. Is there a setting I am missing to activate bank 2L?
Mike
0 项奖励
1 回复
YuanLi_S_Intel
857 次查看
Hi Mike,
No special setting is required. Can you check if the VCCIO power rail is stable? Also, the 3V I/O Bank can use 3.0V and above I/O standard only.
Thank You.
0 项奖励
回复
