21607 Discussions
I can't program the POF file via JTAG for the 10M02DCV36. I can program the sof file, and I can read the UserCode of the device. I can also verify the checksum after I program the SOF file.
RAlac
I also tried to run the jam file. I got the following output fpr the sof file:
c:\intelFPGA_lite\18.1>quartus\bin64\quartus_jli.exe -aConfigure -i output_files\sof_program.jam
Info: *******************************************************************
Info: Running Quartus Prime Jam Tools
   Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
   Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
   Info: Your use of Intel Corporation's design tools, logic functions
   Info: and other software and tools, and its AMPP partner logic
   Info: functions, and any output files from any of the foregoing
   Info: (including device programming or simulation files), and any
   Info: associated documentation or information are expressly subject
   Info: to the terms and conditions of the Intel Program License
   Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
   Info: the Intel FPGA IP License Agreement, or other applicable license
   Info: agreement, including, without limitation, that your use is for
   Info: the sole purpose of programming logic devices manufactured by
   Info: Intel and sold by Intel or its authorized distributors. Please
   Info: refer to the applicable agreement for further details.
   Info: Processing started: Wed May 01 20:00:22 2019
Info: Command: quartus_jli -a Configure -i output_files\sof_program.jam
NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 18.1"
NOTE "DATE" = "2019/05/01"
NOTE "DEVICE" = "10M02DC"
NOTE "NEED_FREQUENCY_CONTROL" = "0"
NOTE "FILE" = "USI_ULTRA.sof"
NOTE "TARGET" = "1"
NOTE "IDCODE" = "031010DD"
NOTE "USERCODE" = "000697A5"
NOTE "CHECKSUM" = "000697A5"
NOTE "SAVE_DATA" = "DEVICE_DATA"
NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A42, A93, A43, A92, A94, A95, A105, A109, A111"
NOTE "STAPL_VERSION" = "JESD71"
NOTE "JAM_VERSION" = "2.0"
NOTE "ALG_VERSION" = "68"
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
   Info: Peak virtual memory: 4261 megabytes
   Info: Processing ended: Wed May 01 20:00:23 2019
   Info: Elapsed time: 00:00:01
   Info: Total CPU time (on all processors): 00:00:00
RAlac
And I got the following output for pof file:
c:\intelFPGA_lite\18.1>quartus\bin64\quartus_jli.exe -aProgram -c1 output_files\USI_ULTRA.jam
   Info: Processing started: Wed May 01 20:01:33 2019
Info: Command: quartus_jli -a Program -c 1 output_files\USI_ULTRA.jam
Device #1 IDCODE is 031010DD
configuring SRAM device(s)...
No SLD hub
No SLD node
Unrecognized device
Exit code = 6... Unrecognized device
Error: Quartus Prime Jam Tools was unsuccessful. 0 errors, 0 warnings
   Error: Peak virtual memory: 4262 megabytes
   Error: Processing ended: Wed May 01 20:01:34 2019
   Error: Elapsed time: 00:00:01
   Error: Total CPU time (on all processors): 00:00:00
CalvinJoaz_P_Intel
Hi Rob, These error messages could displayed because your design is using too many logic resources that is actually too large to fit in your device. What device you're using? Thank you.
RAlac
I'm using the 10M02DCV36. The following is my compilation report. It's a fairly simple design.
Flow Status   Successful - Wed May 01 19:54:03 2019
Quartus Prime Version   18.1.0 Build 625 09/12/2018 SJ Lite Edition
Revision Name   USI_ULTRA
Top-level Entity Name   USI_ULTRA
Family   MAX 10
Device   10M02DCV36I7G
Timing Models   Final
Total logic elements   345 / 2,304 ( 15 % )
Total registers   213
Total pins   18 / 27 ( 67 % )
Total virtual pins   0
Total memory bits   0 / 110,592 ( 0 % )
Embedded Multiplier 9-bit elements   0 / 32 ( 0 % )
Total PLLs   1 / 1 ( 100 % )
UFM blocks   0 / 1 ( 0 % )
ADC blocks   0
RRomano001
Hi RAlac, can I suggest try an old version of programmer?
I experience same trouble and release 15.0 programmed successfully MAX 10 devices.
I am using Linux, but same version don't program .pof
