21602 Discussions
I can't solve the wrong with a stop watch desiging
I was designing a stop watch this week,but get some troubles.
There are four keys---reset,stop,minset(minute set),and secset(second set) in the watch.The reset and stop fuctions are right,but the minset and the secset won't make the minute or the second +1 successfully,and show some error numbers.I don't know why.
This is my code:
module SECLOCK(clk,sclk,rundir,key);
input clk,sclk;//clk--system clk,sclk---percentage second
input rundir;//run direction
input[3:0] key;// 4 keys
reg[32:0] j;//the total percentage seconds,to generate min,sec,percentage second
reg run;//stop mark
reg keyclk;
reg ssclk;
always @(posedge clk)//scan the keys' value,when key!=0,keyclk set high
begin
if(key!=0) keyclk<=1;
else keyclk<=0;
end
always @(sclk)//avoid the conflict between keyclk and ssclk
begin
if(keyclk!=0) ssclk=0;
else ssclk=sclk;
end
always @(posedge keyclk or posedge ssclk)
begin
if(keyclk)
begin
case(key0)
4'b0001://reset
begin
j<=0;
run<=0;
end
4'b0010://stop
begin
run<=~run;
end
4'b0100://set second + 1
begin
j<=j+33'd100;
end
4'b1000://set min + 1
begin
j<=j+33'd6000;
end
endcase
end
else
begin
if(run==1 && rundir==1 ) //forward count
j<=j+1;
else if(run==1 && rundir==0 && j>0) //reward count
j<=j-1;
end
end
endmodule
I hope somebody could help sovle it .Thanks.
An edge sensitive always block must have only one input clock exclusively.
Generally, you should tell about the reported errors.
No errors,the report shows.
I use the signaltap 2 to monitor the signals' changes.the control signal's chang is correct,but the “j” changed not rightly.
If using one input clock exclusively ,how should I modify my code?
I would give more detail information tomorrow.
The signaltap show ,the error is focused on “ssclk”.
I divided the keyclk fuction and ssclk fuction. The project ran normally. When the keyclk have a posedge edge ,”j” add 6000 or 100 correctly.
When I get them together ,the wrong appeared. It seemed that I hadn’t hold the ssclk signal low during during the keyclk hold high.
The key error is here ,I think:
begin
else ssclk=sclk;
end
but why?
In Quartus synthesis, the said always@(sclk) block works as a simple conditional assignment:
assign ssclk=(keyclk)?0:sclk;
But keyclk must be added to the sensitivity list to get the same result in other tools, too. I don't understand the purpose of the operation, however.
Regarding the always @(posedge keyclk or posedge ssclk) block, my first comment wasn't exact. keyclk is an asynchronous reset, in so far it's legal. But you can't have expressions like j<=j+33'd100; in the asynchronous reset part, because you can't build a counter from latches.
I fear, you're missing a clear concept of the overall design.
four keys(posedge keyclk touch off):
(1)reset:j=0,run=0;
(2)stop:run=~run;
(3)sec:j=j+100;
(4)min:j=j+6000;
sclk:50MHz(clk)->100HZ(sclk)
1% second count(posedge sclk touch off): j=j+1;---->ssclk touch off(avoid conflict between keyclk or ssclk)
I add the keyclk to the sensitivity list later(Sorry,I didn't know that error before),but have not any change.
I can't understand the sentence of"you can't build a counter from latches".
Can you explain it for detail.
I give a .doc file,to show a successful case.If you need the project,I will send it.
If the overall design is wrong ,how should I do it.I really have not any ideas now.
I get it!
I used one trigger source to replace the old sources,and get successed.
So interesting the end is.
But I really want to know why my old codes excute exceptionally. I use the signaltap to monitor the signal,and the result is out of logic.
Fvm,Thanks for your help.
