21615 Discussions
I get message error when trying to install devices in quartusII
I get this message: There has been an error.
Unknown element arria10_part1.
the application will exit now.
Anyone know why?
Please Help
Are you installing web edition or subscription edition?
--- Quote Start ---
--- Quote End ---
Web edition
The web edition doesn't support Arria 10.
Cheers,
Alex
As far as I know, QII 15.0 Web edition supports A10. I found few KDB solutions documented with the similar error.
you might see another error with part 2, part 3 etc. Make sure all .qdz folder are located in the same folder. https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05272015_577.tablet.html
By the way, web edition does not support Arria 10 devices. You may refer to https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss_quartussevswe.pdf
Thanks to all for your advices. I will try again.
Greetings
Problem solved!!!
I installed the patch, and it works correctly finally.
Thanks a lot parapapap!!!
Cheers
That's great! Good luck with your project:)
Hi parapapap,
Thanks for the sharing on the patch.
--- Quote Start ---
--- Quote End ---
Thanks a lot
--- Quote Start ---
--- Quote End ---
Hello parapapap, now I have the next problem:
"Problem Details
Error:
Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_family_info_mgr_body.cpp, Line: 287
Failed obtaining data for part 5CGXFC9E6F35I8SD"
I hope you can help me to solve please.
Cheers!
Hi Wen,
This is a QII internal error. I would recommend that you file a service request to MySupport to seek for workaround from Altera.
--- Quote Start ---
Hi Wen,
--- Quote End ---
Thanks Tiny007, I will . :(
Cheers
--- Quote Start ---
Cheers
--- Quote End ---
I install all over again and now it seem to work properly.
Lets see how it works using it.
Fingers cross!!! :p
