21615 Discussions
I got a problem on DE2-TV,I2C_controller
I2C_SCLK begins at SD_COUNTER 4 and ends at SD_COUNTER 30,while I2C_SDAT begins at SD_COUNTER 3 and ends at SD_COUNTER 29.Why don's they transfer data in the same time.
IN addation ,I2C_SDAT also don't write into I2C_SDAT。
The following is partly the program
wire I2C_SCLK=SCLK | ( ((SD_COUNTER >= 4) & (SD_COUNTER <=30))? ~CLOCK :0 );
wire I2C_SDAT=SDO?1'bz:0 ;
always @(negedge RESET or posedge CLOCK ) begin
if (!RESET) SD_COUNTER=6'b111111;
else begin
if (GO==0)
SD_COUNTER=0;
else
if (SD_COUNTER < 6'b111111) SD_COUNTER=SD_COUNTER+1;
end
end
if (!RESET) begin SCLK=1;SDO=1; ACK1=0;ACK2=0;ACK3=0; END=1; end
else
case (SD_COUNTER)
6'd0 : begin ACK1=0 ;ACK2=0 ;ACK3=0 ; END=0; SDO=1; SCLK=1;end
//start
6'd1 : begin SD=I2C_DATA;SDO=0;end
6'd2 : SCLK=0;
//SLAVE ADDR
6'd3 : SDO=SD[23];
6'd4 : SDO=SD[22];
6'd5 : SDO=SD[21];
6'd6 : SDO=SD[20];
6'd7 : SDO=SD[19];
6'd8 : SDO=SD[18];
6'd9 : SDO=SD[17];
6'd10 : SDO=SD[16];
6'd11 : SDO=1'b1;//ACK
//SUB ADDR
6'd12 : begin SDO=SD[15]; ACK1=I2C_SDAT; end
6'd13 : SDO=SD[14];
6'd14 : SDO=SD[13];
6'd15 : SDO=SD[12];
6'd16 : SDO=SD[11];
6'd17 : SDO=SD[10];
6'd18 : SDO=SD[9];
6'd19 : SDO=SD[8];
6'd20 : SDO=1'b1;//ACK
//DATA
6'd21 : begin SDO=SD[7]; ACK2=I2C_SDAT; end
6'd22 : SDO=SD[6];
6'd23 : SDO=SD[5];
6'd24 : SDO=SD[4];
6'd25 : SDO=SD[3];
6'd26 : SDO=SD[2];
6'd27 : SDO=SD[1];
6'd28 : SDO=SD[0];
6'd29 : SDO=1'b1;//ACK
//stop
6'd30 : begin SDO=1'b0; SCLK=1'b0; ACK3=I2C_SDAT; end
6'd31 : SCLK=1'b1;
6'd32 : begin SDO=1'b1; END=1; end
endcase
end
Hope for the answer &#65292;thanks
the first couple of counts sets up the start condition for the write process and the last couple of counts are the end condition. I2C_DAT is the program data coming into this module and I2C_SDAT is the serial data going to the codec. Hope this helps
--- Quote Start ---
--- Quote End ---
Thanks for your help.According to your explanation I understand it.
And I hope you can help me to solve another problem:
It is the above problem too.It looks like that, the data does not transferred to the slave chip.When the data is "0",the controller writes 0 to I2C_SDAT,but when it is "1",the controller writes "z" to I2C_SDAT ,so writing is shut up. It is about I2C_BUS.
Thank you very much!
I didnt get it myself but you can change it so it either gives '0' or the data bit to be sent. It works either way.
Thank you ,I will have a try.
