21592 Discussions
I need yor hlp.....
Hello!!!
this code for the first component of QPSK modulator(serial to parellel converter.the second compnent is NRZ,i need to know how can I integrate the output of serial to parellel with NRZ.
this code of(s to p):
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity FFF is
Port ( S : out bit;
R : in bit;
clk : in bit;
P : in bit_vector (7 downto 0));
end FFF;
architecture Behavioral of FFF is
--signal shift_reg : std_logic_vector(7 downto 0);
begin
process (clk,R,P)
variable shift_reg : bit_VECTOR(7 downto 0);
begin
if R ='0' then
shift_reg(7 downto 0) := P(7 downto 0);
elsif (clk'event and clk='1') then
S <= shift_reg(7);
--shift_reg (7 downto 1) := shift_reg(6 downto 0);
shift_reg (7 downto 0) := ( shift_reg (6 downto 0) & shift_reg(7) );
end if;
end process;
end Behavioral;
this code for NRZ:----------------UNIPOLAR TO BIPOLAR---------------[LOGIC 0=-1, LOGIC 1=1]-------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.std_logic_signed.all;
USE ieee.numeric_std.all;
------------------defines two types: unsigned and signed
ENTITY unipolar_bipolar IS
PORT(
in_i,in_q : IN std_logic_vector (3 downto 0); -------4 bit-------
bI,bQ: OUT std_logic_vector (3 downto 0) -------4 bit-------
END unipolar_bipolar ;
ARCHITECTURE beh OF unipolar_bipolar IS
signal p: integer;------------out
signal k: integer;-------------in
signal n: std_logic_vector(3 downto 0);--------------out(final)
signal i:integer; -----------------------for loop 0 until 3 (4 bit)-----------
begin
for i=> '0';
LOOP
i=n;
when in_i(n)=> k & in_q(n)=> k then
case k is
when k ='0' then -----must invert to signed value---[-1]
p <= '1'; -------in std_logic
out_q(n)<= conv_integer(p);
out_i(n) <= conv_integer(p); --------convert into integer(signed)
end case;
case k is
when k ='1' then-----must invert to unsigned value--[1]
out_q(n)<= conv_integer('0'& p);
out_i(n) <= conv_integer('0' & p); --------convert into integer(unsigned)
end case;
n = i+1;
when n='3' loop;
end LOOP;
end beh;
I hope help me as soon as possible:confused: :confused: :confused:
