21602 Discussions
I2C Sensor reading only zero
PS remove slashes from https in links to access, forum wont let me post them
Hello all,
I'm working on a project using the DE2 board. I made my system in SOPC builder using the OpenCores I2C-Mster core. The one with wishbone connections etc. I have the SCL and SDA connected to GPIO pins in which I am connected to a SENSIRION SHT21 sensor.
(h/ttp://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT21_Datasheet_V3.pdf)
As I run my program, when I check for the retrieved data, the memory location only has 0's. Is there possibly something I am missing? See screenshots of SOPC and my program below.
Any help would be amazing
