21615 Discussions
If there is no output port in code, Why the project will use 0 LEs after compilation?
Hi!
Everyone,
Nowdays I meet a question , If there is no output port in code, Why the project will use 0 LEs after compilation?
For example;
This is a short code with output port:
module IF_CASE1(clk,rst,datain/*,dataout*/);
input clk;
input rst;
input [3:0]datain;
//output [2:0]dataout;
reg [2:0]dataout;
always@(posedge clk)
begin
if (rst==0)
begin
dataout<=0;
end
else
begin
if (datain<4)
dataout<=1;
else if (datain<8)
dataout<=2;
else if (datain<12)
dataout<=3;
else
dataout<=4;
end
end
endmodule
and the printscreen is below after compilation.
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_%e6%88%aa%e5%9b%be2.jpg
but if the project has output port , the result is different from above.
you can see the compilation message.
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_%e6%88%aa%e5%9b%be1.jpg
Can you make a distinction bewteen the two situlations in detail?
Thanks!
If the design has no output, the synthesisor can remove all logic elements in the design because they serve no purpose.
Here is a simple case: assign B = A; assign C = B; Now assume that C doesn't get used anywhere in your design or hooked up to a pin, Quartus II will determine that there is no point keeping C. Now if A and B are not used anywhere else in your design then A and B will be removed since C is removed. If you are familiar with C code compilers the behavior is similar to the optimizations they do.
I see,thanks for your reply! BadOmen
