21591 Discussions
Image file generation for non-Altera serial configuration devices
I am using AIIGX fpga along with serial configuration device from Micron. We are using AS configuration mode, in relation to this I have following queries, any help on this would be appreciated.
1. Is AIIGX fpga support non-Altera serial configuration devices?
2. If it is possible then how can I generate a bit stream target to non-EPCS part (in my case Micron device, data sheet attached)?
3. Is there any particular care needed on PCB level to handle above scenario?
R Shaik.
Yea I know this is really disappointing but in AS mode you probably have to go with the Altera serial configuration devices. Maybe it is possible with a third party SPI flash but there is no documentation and support for this. So it is your risk to try it.
Check these links:
* configuration comparison (http://www.altera.com/support/devices/configuration/cfg-compare.html
* arria ii configuration handbook (http://www.altera.com/literature/hb/arria-ii-gx/aiigx_51009.pdf)
Instead of guessing,I suggest to search the forum for M25P32, preferably start reading the newest entry. The question had been definitely answered.
