Programmable Devices
Ankündigungen
21615 Diskussionen
Inout questions in testbench
Geehrter Beitragender II
1.720Aufrufe
Hi to all :)
after doing a certain number of exercizes, about a PWM and an Encoder, I'm doing the first example of a simple PLD. In this example, I use two bus from a DSP: an address bus, and a data bus.
The address bus permits, thanks to 2 encoders, to tell the PLD what functionality or module to be active.
The data bus gives and receives data to and from this modules.
The problem I can't solve is this. The data bus has to be bidirectional, so inout type.
My aim is this: when write signals for PWM arrive, this bus has to be read, while when read signal for Encoder arrives the bus has to be write.
This is the code I have written:
dat_A <= dat_dsp(13 downto 0) when wr_pwmA = '1' else dat_dsp_reg(13 downto 0); dat_B <= dat_dsp(13 downto 0) when wr_pwmB = '1' else dat_dsp_reg(13 downto 0); dat_C <= dat_dsp(13 downto 0) when wr_pwmC = '1' else dat_dsp_reg(13 downto 0); dat_rit <= dat_dsp(14 downto 0) when rit_pwm = '1' else dat_dsp_reg(14 downto 0); uscita_bus_dati : process(rd_enc1,rd_enc2) begin if rd_enc1 = '1' then dat_dsp <= out_enc1; elsif rd_enc2 = '1' then dat_dsp <= out_enc2; else dat_dsp <= (others => 'Z'); end if; end process;
where:
- dat_A, dat_B and so on are data to be given to the PWM
- wr_pwmA and so on are abilitation write signals
- rd_enc1 and rd_enc2 are abilitation read signals
- dat_dsp is the bidirectional port
The first part is about dat_dsp used as input, the second as output.
After this, I tried a testbench. I wanted to simulate this behaviour:
I send on dat_dsp the input for PWM, after I enable the Encoder and, after a certain time, I want to read it, so sending the reading on dat_dsp.
I wrote this:
dato_PWM : process begin tdat_dsp <= "00000000000000000000001110000100"; wait; end process;
where I force dat_dsp (tdat_dsp is the name in the testbench) at this value at the beginning to make work PWM.
Now the problem is that i think that it works, but Modelsim thinks that I force dat_dsp on this values as I would do with an output so I would see errors in the functionality of the circuit.
So, when it would have to write on data bus, the result is a vector where there are some X for the bits of the encoder exit different from the value I have forced at the beginning!
Is there any other mode, maybe righter, to tell a testbench that I want only to use that value as a signal, instead of force it for all the simulation time?
Thanks and sorry for the very long question
4 Antworten
639Aufrufe
Does the top level not output some form of direction signal? like a write-enable or read enable?
if it does, then the testbench process can just do this:
dato_PWM : process(read_en) begin if read_en = '1' then tdat_dsp <= "00000000000000000000001110000100"; else --UUT is trying to write data to testbench tdata_dsp <= (others => 'Z'); end if; end process;
639Aufrufe
it works! thank you very much!
639Aufrufe
ok I have another question on this issue.
now it works, but if I write:
modelsim thinks that it's like I force tdata_dsp to Z. So, when I enable the writing on the bus it writes, but when I remove the enable, tdat_dsp returns Z...
so it's like tdata_dsp is always a input, except when I enable the write...
I would like that when I enable the write, tdata_dsp changes its status to an output, until it will return an input (if this happens).
Anyway, my doubt is: is this a problem of the testbench, or I will see a similar behaviour even in real?
639Aufrufe
What you see in the simulation depends on your logic design and on your test bench.
What you'll see in the simulation will depend on your logic design and whatever it's connected to.
So... your testbench should model the real world as closely as needed.
Antworten
