21611 Discussions
Instantiate Max 10 ADC in VHDL
I'm sure this has been covered, but I can't seem to get Quartus to make the connection. I have a design that is 99% straight VHDL, but I need to monitor a couple of power supplies, so I routed scaled versions to the Max 10 ADC. I built a Qsys component for a simple ADC-only core and tried to instantiate it in my VHDL design, but I keep getting an error that an entity was used without being declared.
Now, I get that everything Quartus is generating is in Verilog, so I verified the case was correct, but still no dice. I know Quartus is aware of the ADC core because I see the messages about its generation during the build.
I named the core "lsm_emulator_adc", and it has a corresponding "lsm_emulator_adc.qsys" file which I brought into Quartus. I then mapped it in my HDL using a variety of methods, but at the moment:
U_ADC : entity lsm_emulator_adc.lsm_emulator_adc_modular_adc_0
port map (
adc_pll_clock_clk => ADC_Clock, -- adc_pll_clock.clk
adc_pll_locked_export => ADC_Locked, -- adc_pll_locked.export
clock_clk => SIM_Clock, -- clock.clk
command_valid => Command_Valid, -- command.valid
command_channel => Command_Channel, -- .channel
command_startofpacket => Command_SoP, -- .startofpacket
command_endofpacket => Command_EoP, -- .endofpacket
command_ready => Command_Ready, -- .ready
reset_sink_reset_n => Reset_n, -- reset_sink.reset_n
response_valid => Response_Valid, -- response.valid
response_channel => Response_Channel, -- .channel
response_data => Response_Data, -- .data
response_startofpacket => Response_SoP, -- .startofpacket
response_endofpacket => Response_EoP -- .endofpacket
I even tried declaring the component to see if that would resolve it, but so far no.
Can anyone help me figure out what I am doing wrong, or show me how to connect to the Max 10 ADC from a VHDL project?
Thanks!
In the parameter editor (Qsys) from the Generate menu, did you look at the instantiation template? That should help you out.
Can you post the component declaration and the exact error messages you're getting including messages just before the error?
Ok, well you were right. I missed something subtle in the instantiation file because I was used to doing it the regular way.
Using component instead of entity fixed it:
U_ADC : component lsm_emulator_adc
port map (
I'm not sure if including the library made a difference or not. It's still in the HDL, but it may not be necessary. Thanks for the hint!
