21602 Discussions
Intel Devstack-OpenCL unable to detect PAC Cards
Saikiranbelana
Intel Development Acceleration Stack for OpenCL is not detecting the Arria 10 PAC Cards on our server. It's looking for PAC drivers which cannot be found at the OpenCL_BSP installation path.
The Cards can be detected using `lspci` and `OPAE drivers` but not with `aocl diagnose` command:
System Specs:
OS: ubuntu - 18.04
The following is the log:
server2@ubuntu:~$ sudo fpgainfo fme
Board Management Controller, microcontroller FW version 26895
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xEE00001
PCIe s:b:d:f                  : 0000:AF:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x124000200000367
Bitstream Version             : 1.2.4
Pr Interface Id               : 38d782e3-b612-5343-b934-2433e348ac4c
Boot Page                     : user
Object Id                     : 0xEE00000
PCIe s:b:d:f                  : 0000:86:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Boot Page                     : user
server2@ubuntu:~$ source ~/inteldevstack/init_env.sh
export QUARTUS_HOME=/opt/intelFPGA_pro/quartus_19.2.0b57/quartus
export OPAE_PLATFORM_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv
export AOCL_BOARD_PACKAGE_ROOT=/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp
source /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh
$OPAE_PLATFORM_ROOT/bin is in PATH already
sudo cp /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/sw/afu_platform_info /usr/bin/
export INTELFPGAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld
export ALTERAOCLSDKROOT=/opt/intelFPGA_pro/quartus_19.2.0b57/hld
$QUARTUS_HOME/bin is in PATH already
source /opt/intelFPGA_pro/quartus_19.2.0b57/hld/init_opencl.sh
server2@ubuntu:~$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
        /etc/OpenCL/vendors
Found 2 icd entry at that location:
        /etc/OpenCL/vendors/Altera.icd
        /etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
the following OpenCL libraries are referenced in the icd files:
        libalteracl.so
        libintelocl_emu.so
checking LD_LIBRARY_PATH for registered libraries:
        libalteracl.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib
        libintelocl_emu.so was registered on the system at /opt/intelFPGA_pro/quartus_19.2.0b57/hld/host/linux64/lib
Using the following location for fcd installations:
        /opt/Intel/OpenCL/Boards
Found 2 fcd entry at that location:
        /opt/Intel/OpenCL/Boards/a10_ref.fcd
        /opt/Intel/OpenCL/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
        /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so
        /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so
        /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/lib/libaltera_a10_ref_mmd.so was registered on the system.
        /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 2
        1. Intel(R) FPGA SDK for OpenCL(TM)                             | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4
        2. Intel(R) FPGA Emulation Platform for OpenCL(TM)              | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
ICD diagnostics PASSED
BSP Diagnostics
Error initializing DMA: no memory
Error initializing mmd dma
Error closing DMA
Error initializing bsp
Error closing DMA
Warning:
No devices attached for package:
Unable to find the kernel mode driver.
Please make sure you have properly installed the driver. To install the driver, run
      aocl install
DIAGNOSTIC_FAILED
Warning:
Error closing DMA
Error closing DMA
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
server2@ubuntu:~$ aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] y
aocl install: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is already registered in the system, please uninstall it before reinstalling
server2@ubuntu:~$
Please help us fix this @intel  @BoonBengT_Altera  @JohnT_Intel
Thank you,
Saikiran
JohnT_Intel
Can you try running "aocl uninstall" and "aocl install" to see if the issue is resolved?
Saikiranbelana
When I try to reinstall, It says binary operator expected. Here's the log
server2@ubuntu:~$ aocl uninstall
Do you want to unset the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
aocl uninstall: /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp is not installed, no need to uninstall.
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] n
Please specify a directory to setup FCD:
aocl install: Setting up the FPGA Client Driver (FCD) to the system. This process may require admin privilege
Install the FCD file to /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp
aocl install: Adding the board package /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp to the list of installed packages
Installing the board package driver to the system.
aocl install: Running install from /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec/install: line 15: [: /dev/intel-fpga-port.0: binary operator expected
JohnT_Intel
Can you try to performed "lspci" and check if the driver is bind to the device? The reason is that when you are performing uninstall, the driver is not bind to the device.
Saikiranbelana
As suggested, I have bound the device using `lspci`.  Below is the log.
server2@ubuntu:~$ sudo lspci -n -v -s 0000:af:00.0
af:00.0 1200: 8086:09c4
	Subsystem: 8086:0000
	Physical Slot: 5
	Flags: bus master, fast devsel, latency 0, IRQ 39, NUMA node 1
	Memory at dbffff00000 (64-bit, prefetchable) [size=512K]
	Memory at dbfffe00000 (64-bit, prefetchable) [size=1M]
	Capabilities: [68] MSI-X: Enable+ Count=7 Masked-
	Capabilities: [78] Power Management version 3
	Capabilities: [80] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [160] Alternative Routing-ID Interpretation (ARI)
	Capabilities: [200] Single Root I/O Virtualization (SR-IOV)
	Capabilities: [280] #19
	Kernel driver in use: intel-fpga-pci
	Kernel modules: intel_fpga_pci
server2@ubuntu:~$ sudo lspci -n -v -s 0000:86:00.0
86:00.0 1200: 8086:09c4
	Physical Slot: 7
	Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 1
	Memory at d7ffff00000 (64-bit, prefetchable) [size=512K]
	Memory at d7fffe00000 (64-bit, prefetchable) [size=1M]
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [Y/n] Y
Install the FCD file to /opt/Intel/OpenCL/Boards
aocl install: Running install from /opt/intelFPGA_pro/quartus_19.2.0b57/hld/board/a10_ref/linux64/libexec
cp: cannot stat '/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/driver/*': No such file or directory
sh: 0: Can't open ./make_all.sh
aocl install: failed.
aocl install: Removing FCD
aocl install: Removing the board package /home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp from the list of installed packages
For some reason, `aocl install` command is searching for the driver folder which is non-existent in the BSP.
I'm not sure how to diagnose this.
JohnT_Intel
Can you check your "'/home/server2/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64"? I suspect that you have not un-archive or unzip the opencl BSP.
JohnT_Intel
Have you check if the BSP is there?
Saikiranbelana
Hi JohnT, Sorry for the delayed response.
The following are the available files in the linux64 folder
server2@ubuntu:~/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64$ tree
├── lib
│   └── libintel_opae_mmd.so
└── libexec
    ├── diagnose
    ├── flash
    ├── install
    ├── program
    ├── setup_permissions.sh
    ├── sign_aocx.sh
    └── uninstall
2 directories, 8 files
The Installer script extracts the opencl_bsp drivers.
JohnT_Intel
Saikiranbelana
yes, I have followed the same steps. The problem occurs the same.
The following is the output when I try to uninstall and reinstall the BSP:
server2@ubuntu:~$ aocl list-devices
Warning:
JohnT_Intel
From the latest log, it looks like it is able to installed the driver. Can you double confirm using "lspci" to see if the driver is loaded into the FPGA card?
Saikiranbelana
Hi @JohnT_Intel , Here's the output for lspci
server2@ubuntu:~$ lspci | grep acce
af:00.0 Processing accelerators: Intel Corporation Device 09c4
The FPGA is still available and only shows with lspci and fpgainfo. I think the problem is with the drivers. When I move the FPGA to a different system, It works there.
JohnT_Intel
Can you try "lspci -vv | grep acce" to get the kernel driver information.
Saikiranbelana
Here's the output for `lspci -vv | grep acce`:
server2@ubuntu:~$ sudo lspci -vv | grep acce
for `lspci -vv` :
	Subsystem: Intel Corporation Device 0000
	Physical Slot: 5
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 39
	NUMA node: 1
	Region 0: Memory at dbffff00000 (64-bit, prefetchable) [size=512K]
	Region 2: Memory at dbfffe00000 (64-bit, prefetchable) [size=1M]
		Vector table: BAR=0 offset=00009000
		PBA: BAR=0 offset=0000a000
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [80] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
			MaxPayload 256 bytes, MaxReadReq 4096 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x8, ASPM not supported, Exit Latency L0s <4us, L1 <1us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
			 EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
	Capabilities: [160 v1] Alternative Routing-ID Interpretation (ARI)
		ARICap:	MFVC- ACS-, Next Function: 0
		ARICtl:	MFVC- ACS-, Function Group: 0
	Capabilities: [200 v1] Single Root I/O Virtualization (SR-IOV)
		IOVCap:	Migration-, Interrupt Message Number: 000
		IOVCtl:	Enable- Migration- Interrupt- MSE- ARIHierarchy+
		IOVSta:	Migration-
		Initial VFs: 1, Total VFs: 1, Number of VFs: 0, Function Dependency Link: 00
		VF offset: 1, stride: 1, Device ID: 09c5
		Supported Page Size: 00000553, System Page Size: 00000001
		Region 0: Memory at 00000dbfffd00000 (64-bit, prefetchable)
		Region 4: Memory at 00000dbffff80000 (64-bit, prefetchable)
		VF Migration: offset: 00000000, BIR: 0
	Capabilities: [280 v1] #19
JohnT_Intel
Thanks for providing the logfile. From the logfile, it looks like it automatically loaded with default PCIe driver. Please performed "modprobe -r intel-fpga-pci" then only performed "aocl install".
JohnT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Saikiranbelana
I couldn't fix the error occurring. So, I had to reinstall the OS and install the inteldevstack on it. It works now.
Thanks, @JohnT_Intel  for the support.
