21584 Discussions
Intel® JHL7440 Thunderbolt™ 3 Controller (QE17863)
JLiu18
Hi Tech,
part# JHL7440 S LMHZ
There is no PIN definition and packaging of above IC in the data sheet, so we cannot build a library in the software for principle and layout.
18-241_Thunder7000Controller_Brief_FIN_HI-1661831.pdf (mouser.com)
Could you help to provide the PIN definition and Layout package for this part?
Alberto_R_Intel
JLiu18, Thank you for posting in the Intel® Communities Support.
I just transfer your thread to the proper department. They will further assist you with this matter as soon as possible.
Albert R.
JLiu18
Hi Albert,
May I get update on this request?
JLiu18
Hi Albert,
Kindly following up.
Jun Liu
JLiu18
Hi Albert,
Sorry for pushing but our customer is waiting for the reply urgently.
Could you help check the update on this case?
Or share with me the correct channel for submitting the case?
Jun Liu
Lubo
Could you confirm that PN: JHL7440 SLMJ2 is correct for tape and reel version?
I'm also looking for RoHS 3 CoC file of this controller.
Will you be able to help me?
Thank you!
OŠ
Hello , do you have any updates ?
It seems that I have the same issue.
I want to build a device using the JHL7440 SLMJ2
TBT controller. However there is no Pin-out or EDA and CAD files avalible online. I have already texted Mouser el. about this issue ,
but I've letted them know that I'll contact you first.
Please , are this pin-outs marked as confidential and can I wiew them in Quartus EDA software?
If so , can I reach the same results with Cyclone FPGA and a bit of Verilog programming , or PCIe and USB3.2 XHCi
perhaps if you got any bridges or PHY ?
Also , considering this situation I want to connect GPU using TBT as an endpoint device and have a laptop that has already
TBT built inside can the TBT interface auto-detect PCIe ? I looked at your datasheet and in layman's term it seems to be
simplified to an extreme stupid simplicity that it's basically just a switch between USB , PCIe and DP.
Also got any recomendations for PCIe and USB switching device ? I looked for Broadcom and they seem nice to me
Please reply ASAP , thank you
Thank you in advance
Ondrej
EDITED : I'm ataching datasheet from mouser el. Here is the link https://www.mouser.sk/ProductDetail/Intel/JHL7440-S-LMHZ?qs=MLItCLRbWswTHfM8e%252BJB6w%3D%3D
Jocelyn_Intel
Hello, Everyone.
Thank you for posting on the Intel® communities. We are sorry for the delay.
Please be aware that you need to register on Intel® Resource and Documentation Center (RDC) for this type of information, and if you get full access, you can access to the Titan Ridge DD Thunderbolt Interface Controller Datasheet. Please check the following article to apply for an RDC account:
How to Apply for an Intel® Resource and Documentation Center (RDC) and/or Intel® Developer Zone (Intel® DevZone) Account
Since this is out of our scope, this thread will no longer be monitored, but if you need further assistance with another matter, feel free to contact us back and submit a new post.
Jocelyn M.
OŠ
Hello, no worries about the delay. I'll take a look after vacation.
This helped me a lot, and I think others as well.
I'll also inform mouser electronics.
Thank you very much
Ondrej
