Hi Team
I try to generate SR-IOV example refer to the "Intel® L- and H-tile Avalon® Streaming and Single Root I/O Virtualization (SR-IOV) IP for PCI Express* User Guide " to running on the Stratix® 10 FPGA Development Kit " DK-DEV-1SGX-L-A " . When I select Device " 1SG280HU2F50E2VG" , there have option to enable the sr-iov ,
When I select Device " 1SG280LU2F50E2VG" , there have not option to enable the sr-iov .
Is the device 1SG280LU2F50E2VG does not support SR-IOV?
I tried to create an example design using the settings that you have provided and keep others as default. The design example generation is successful.
May I know which software edition / version you are using? Can you use the latest version?
KhaiY
Hi KhaiChein
I use the Quartus Prime Pro 21.1
Does your example select the device 1SG280LU2F50E2VG ? and enable the SR-IOV?
I am using 1SG280HU2F50E2VG. Please allow me some time to try using 1SG280LU2F50E2VG.
KhaiY
Hi Mark,
Yes. Single Root I/O Virtualization (SR-IOV) support is added for H-Tile variants only.
You may refer to the release note https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-s10-pcie.pdf
KhaiY
Hi KhaiChein
Thanks a lot for you answer.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
