21602 Discussions
Intel Max 10 Part # 10M02DCV36I7G and I2C communications?
Alick1
Does anyone know if the Intel Max 10 Part # 10M02DCV36I7G can be configured to be an I2C Slave?  If so, how?
What development board and software would work to emulate Intel Max 10 Part # 10M02DCV36I7G?
I appreciate any help with these questions.
FvM
just need to write the I2C slave code, or copy it from any of the available sources, just search for "fpga i2c slave".
Alick1
Thanks for your reply!
How to I determine if the Intel Max 10 Part # 10M02DCV36I7G has enough logic element cells and memory to be able to perform a dedicated I2C, JTAG interface, and basic processing tasks?
How do I determine which pins to use for I2C?
I can't seem to find a specific data sheet for this part, only general information.  I did find the document, "Pin Information for the Intel MAX 10 10M02DC Device Version 2017.02.21" from which the JTAG interface is apparent, but not sure about the I2C assignments.  Any ideas?
Thanks for your help!
ALick1
