Programmable Devices
21602 Discussions
Interface between HPS and FPGA for UART connection
Trying to interface HPS and FPGA for UART connection. Have done the interfacing using Qsys. The FPGA is Cyclone V DE1 SoC board. Compiling the code gives the following error. Error (35030): Partition "fpgahps_hps_0_hps_io_border:border" contains I/O cells that do not connect to top-level pins or have illegal connectivity Error (35032): Output port "fpgahps:u0|fpgahps_hps_0:hps_0|fpgahps_hps_0_hps_io:hps_io|fpgahps_hps_0_hps_io_border:border|mem_dm[0]" on partition "fpgahps_hps_0_hps_io_border:border" must drive a top-level pin but is driving "" Error (35032): Output port "fpgahps:u0|fpgahps_hps_0:hps_0|fpgahps_hps_0_hps_io:hps_io|fpgahps_hps_0_hps_io_border:border|mem_dqs[0]" on partition "fpgahps_hps_0_hps_io_border:border" must drive a top-level pin but is driving "fpgahps:u0|fpgahps_hps_0:hps_0|fpgahps_hps_0_hps_io:hps_io|fpgahps_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|strobe_in"fpgahps is the name of the Qsys file.Can anybody help?
