Hi All
I'm using ArriaII GX. in my proj , it contains 4 ddr3 controller(altmemphy) Compile the proj, with QuartusII 10.1/11, when assembler ,it returns an error Internal Error: Sub-system: ASMIO, File: /quartus/comp/asmio/asmio_dqs.cpp, Line: 4477 temp_result == result Stack Trace: 0x3441f: ASMIO_MIO_DQS_DELAY_CHAIN_INPUT_SELECT::process_atom + 0x2bf (comp_asmio) 0x14cd98: process_cdb + 0x5a8 (comp_asm) 0x14d942: assemble_chip + 0x302 (comp_asm) 0x14ffde: assemble_dev_device + 0x12de (comp_asm) 0x1525c0: asm_assemble + 0x380 (comp_asm) 0x3d9a: QASM_FRAMEWORK::execute + 0x6a (quartus_asm) 0xd9e1: qexe_get_tcl_sub_option + 0x981 (comp_qexe) 0x10287: qexe_process_cmdline_arguments + 0x387 (comp_qexe) 0x10374: qexe_standard_main + 0x84 (comp_qexe) 0x3a70: qasm_main + 0x50 (quartus_asm) 0x1cb1: msg_main_thread + 0x11 (CCL_MSG) 0x1bc8: _thr_final_wrapper + 0x8 (ccl_thr) 0x1c25: msg_thread_wrapper + 0x85 (CCL_MSG) 0x6720: mem_thread_wrapper + 0x32 (ccl_mem) 0x2c4a3: msg_exe_main + 0x63 (CCL_MSG) 0x3ccc: _main + 0x1c (quartus_asm) 0x43f1: __CxxThrowException@8 + 0x15f (quartus_asm) 0x17076: RegisterWaitForInputIdle + 0x48 (kernel32) End-trace Quartus II Version 10.1 Build 197 01/19/2011 SJ Full Version Service Pack Installed: 1 How can I fix the error ?? Can anyone help me?Link Copied
