21615 Discussions
Interrupt reading in NIOSII
I am very new to NIOSII programming.
So I generate an interrupt using PIO on QSYS
Direction : Input
Synchronusly capture : Rising Edge
IRQ type: Edge
I export the conduit to connect to an FPGA board pin.
What I want to do is when there is an interrupt generated on this pin I want to be able to read it on NIOSII and use it as a variable in coding.
For example I=interrupt then I want to able to write a onditional for loop
If I=1 then
else....
Does anyone know how to do this in NIOSII??
