21611 Discussions
Is compiled rootfs depends on device ?
rshal2
New Contributor II
Is compiled rootfs depends on device (arria, cyclon ...)?
I am not talking about u-boot or preloader, or dtb, but only about filesystem.
In rocketboard site, I see that there are versions binaries for compiled root filesystem per device, but in the other hand, after reviewing instructions for compiling Linux ,it seems that there is no dependency in device specific, so I am a bit confused on this matter.
FawazJ_Altera
Hello Ran,
Rootfs is device independent. you can use any rootfs with your linux kernel. However, some rootfs packages have specific drivers, applications, packs that are compatible with a specific device. other than that, rootfs is device independent.
hope this might help.
Thank you
FawazJ_Altera
Hello Ran,
Thank you
