21602 Discussions
Issue with updating ARIA 10 PCIe core to 20_1_1
mwf
We are migrating to a new hardware design server and are converting existing FPGA designs from Quartus 17.1 to Quartus 22.3. We have a number of PCIe Gen 3 x 8 designs that build without issue and run fine on the hardware. This is with both Quartus 17.1 and 22.3. Using 22.3 requires an update of the PCIe core to 20_1_1. This core works fine when configured as Gen 3 x 8.
We also have a number of PCIe Gen 2 x 8 designs. They all work fine when built with Quartus 17.1. But the first design I tried builds with 22.3 but doesn't work on the hardware. I get various errors including PC hangs, no access to PIO slave registers, and DMA failures from our FPGA to host (PC) memory.  Changing seeds changes behavior slightly.
I also tried Quartus 19.2 which has an optional PCIe core update to 19_1. This core appears to work fine when configured as Gen 2 x 8.
The PCIe core and a lot of our IP run at 250Mhz. There are no timing errors reported by either Quartus version.
Thanks for any ideas,
Mike
Wincent_Altera
Hi
Glad that the problem is solved, thanks for sharing the answer with me.
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
