21602 Discussions
JTAG Chain with Daughterboard
Hi!
I have problems with the Dual Highspeed AD/DA converter board when using the JTAG chain, I can't find any bypass switch and on the DE3 board I am using JTAG is enabled as soon as a daughterboard is connected. Since this daughterboard doesnt use JTAG, i get chain errors as soon as it is connected and i try to program or use signaltap.
Does anyone know how to disable/bypass the JTAG chain on a specific top-connector or on the dughterboard? The dip-switches can only disable the bottom ones...
