I have a custom board with a MAXII CPLD (EPM2210F256), with the JTAG port built per the Handbook. With Quartus-II v. 9.1 and a ByteblasterMV cable I can ID the device, erase it, and blank-check it with no problem. Only when I try to program it do I get the error: "can't access JTAG chain." I put an oscilloscope on the (4) JTAG signals and the power supply- all look very clean. The data book says "Failures during in-system programming may occasionally be related to the Quartus II software" and says to look on the web site for details. I haven't found any there. Can anyone shed any light on this or suggest other ideas to check? Much appreciated...Link Copied
--- Quote Start --- I put an oscilloscope on the (4) JTAG signals and the power supply- all look very clean. --- Quote End --- What bandwidth is your scope? A low bandwidth ~50MHz scope might not show ringing and steps in the TCK signal due to transmission line reflections. --- Quote Start --- Can anyone shed any light on this or suggest other ideas to check? --- Quote End --- Try another ByteBlaster, or better yet, try a USB-Blaster. If you don't have one, Terasic sells them for $50. They work well. Cheers, Dave
Dave, thanks for your reply. My scope is 200MHz BW, 1Gsa/sec. If there are any glitches they are <10nsec wide and die out very fast.
Probably I will try the Terasic programmer (note Atlera lists their USB-Blaster for $300!). Also in proces of downloading the latest Quartus SW, so we'll see... Thanks again.- Mark as New
--- Quote Start --- My scope is 200MHz BW, 1Gsa/sec. If there are any glitches they are <10nsec wide and die out very fast. --- Quote End --- Ok, the scope sounds good enough. The fact that you do not see any glitches is a good sign. --- Quote Start --- Probably I will try the Terasic programmer (note Atlera lists their USB-Blaster for $300!). Also in proces of downloading the latest Quartus SW, so we'll see... --- Quote End --- Yeah, the Altera versions are way too pricey. The Terasic versions work great! Cheers, Dave
