hello ,
could someone tell me how i can realize a LUT with size 500000 for FPGA in verilog? thanksLink Copied
A LUT with 500,000 entries? And how many bits is each entry?
I suggest you declare an array and then use the inital block to set the values. reg [7:0] lut_rom [0:499_999]; integer i; initial begin for(i = 0; i < 500_000; i = i+1) begin lut_rom[i] = .... end end Reads should be performed in such a way that Quartus can infer a synchronous ROM from this. Otherwise, it will probably not fit and/or be very slow.
