Licesnse Error
Hallo
Anyone know how can I solve the error that when run the DSP builder appear the massage which is written inside it ‘’ Matlab Error Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently ’’
What should I do? I have the license and everything is ok. :confused:
Thank u for your answer
check your license file and make sure the date coincides with the release month of the version you are using.
I am having the same problem. My license was issued May 9th, but I'm using DSP Builder 7.0, because this works with the version of Matlab installed on my machine (Matlab 7.0). Is the date of my license the reason I am getting a license error in Matlab when I try to compile?
Thank you!
you shouldn't have a problem with a new license and older software. have you setup LM_LICENSE_FILE to point at your DSP Builder license? DSP Builder won't look at the QII License setup, only LM_LICENSE_FILE
Hi thepancake,
Thank you for replying! All of the environmental variables, including LM_LICENSE_FILE, were set correctly. I "solved" the problem by getting a new license of Matlab, Matlab R2009a. Now compiling with Quartus II 11.0 and DSP Builder 11.0 works fine (after installing DSP builder 11.0 twice).
