21598 Discussions
Loan I/O DE1-SoC UART0
I am trying to use LOAN I/O to steal HPS UART0 RX/RX for use in my FPGA logic. I.e I have an VHDL UART that I want to connect to UART0 RX/TX pins. Is this possible?
I have read this post: http://www.alteraforum.com/forum/showthread.php?t=44486&highlight=loan+io
And it seems possible. However, in simulation I get no "connection" between HPS_UART_RX and the loaned port. I have setup loan_io_oe (i.e. '1' when output).
This got me thinking (from https://www.altera.com/en_us/pdfs/literature/hb/cyclone-v/cv_5v4.pdf):
the loanio only operates when the hps registers have been set up in the pre-loader to allowtheir operation.
bsp-editor has no checkboxes or options regarding LoanIO.
I am confused, hope someone can clarify.
1) bsp-editor will automatically generate preloader code according to HPS settings in QSYS. ( for example, the GPIO65 set as LoadIO65)
2) HPS pin mux has assigned after preloader running.
3) I think the "loan IO" can't do simulation.
