21595 Discussions
Low Voltage Input
Hi!
I want to feed an SDI Signal with a maximum high level of 800mV into an ALTERA CYCLONEII.
Unfortunatly the FPGA does not recognize this low voltage in my project.
Is there an option, maybe with the appropriate I/O assignment, where I can tell the FPGA to handle this input?
Thanks for your help.
Best regards
drehstrom
Can you describe the source of that SDI signal? And what 'stream of data' if any does it represent?
Cyclone II differential LVDS inputs have a specified common mode voltage of 0.1 to 2.0V. Thus they should be able to receive a 0.8V signal with the negative input connected to a reference voltage of e.g. 0.4 V.
