21615 Discussions
MAX 10 Modular ADC core problem with reserved pins
I want to use only TSD (temperature sensor diode) to monitor chip (10M50SAE144I7G) temperature. When I instantiate 'Altera modular ADC core' in my project with all channels disabled except TSD, fitter says that dedicated input pins ~ALTERA_ADC1INx~ is assigned.
Error (176310): Can't place multiple pins assigned to pin location Pin_8 (IOPAD_X0_Y36_N14) Info (176311): Pin E100_RX_DV is assigned to pin location Pin_8 (IOPAD_X0_Y36_N14) Info (176311): Pin ~ALTERA_ADC1IN3~ is assigned to pin location Pin_8 (IOPAD_X0_Y36_N14)
Is there way to disable pin assignment for unused ADC input/channels?
From datasheet:
--- Quote Start ---
You can use the dual function pins in an ADC block as general purpose I/O (GPIO) pins if you do not use the ADC.
--- Quote End ---
So, if i use ADC block only for TSD... I can not use these pins as GPIO?
Try loading sample projects.
https://cloud.altera.com/devstore/platform/15.1.0/standard/nios-ii-on-die-temperature-sensor-design-example/
--- Quote Start ---
From datasheet:
--- Quote End ---
Yes,even TSD is part of ADC.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Thanx, Anand Raj Shankar!
Is there a chance that this behavior will be changed in the future?
