21602 Discussions
MAX 10 Startup Delay
I am experiencing a long delay between power up and the MAX 10 device starting to operate. This delay can be anything from under 1 second (acceptable) to 40 seconds or more.
  • Device: 10M02SCE144C8G single supply (3.3V) device.
  • Programmer Hardware: ByteBlaster II programmer through the JTAG port.
  • Compiler / Programmer Software: Quartus Prime 16.1.2
Device Settings:
  • Operating Settings and Conditions: Voltage, VCCA voltage: 3.3V
  • Device Assignments -Voltage
  • Default I/O standard: 3.3-V LVTTL
  • Core voltage: 1.2V (default and cannot be changed)
  • Device Assignments - Configuration:
  • Configuration scheme: Internal Configuration
  • Configuration mode: Single Uncompressed Image (96Kbits UFM)
  • Force VCCIO to be compatible with configuration I/O voltage - yes
  • Generate compressed bitstreams - on
  • Device Assignments - General (check boxes):
  • Auto-restart configuration after error - on
  • Release clears before tri-states - off
  • Enable device-wide reset (DEV_CLRn) - off
  • Enable device-wide output enable (DEV_OE) - off
  • Enable nCONFIG,nSTATUS, and CONF_DONE pins - off
  • Enable JTAG pin sharing - off
  • Enable CONFIG_SEL pin - off
  • The Configuration Pins listed above are assigned as outputs to drive logic, except for nCONFIG which is connected to a pull-up resistor (100K to 3.3V) and a push button switch.
  • Power On Reset scheme: Instant ON (this is default and cannot be changed)
Power Supply:
  • Voltage: 3.3V
  • 3.3V Ramp Up time (tRAMP): 980uS
This delay also occurs after programming the device using a .pof file. When using a .sof file to program the device, the start up is instant. I have tried 3 different boards and all three boards have the same issue / behavior.
Any advice / ideas? What am I missing here?
Sean
I have managed to resolve this issue by adding a 10K pull-up resistor (to 3.3V) to the CONF_DONE pin. Device now starts up instantly every time.
Sean
