21615 Discussions
MAX10 ADC device ANAIN1 and bank 1A
Broddo
I have a single supply max10 10m50 (144 pin) and I need to use the modular ADC IP. I only need one ADC channel in the design - the signal is connected ANAIN1 pin.
I'm not using any part of bank 1A for the ADC but I am using these pins for digital IO. Quartus cannot compile the design saying:
176310 Can't place multiple pins assigned to pin location Pin_8...
I understand that I cannot use any pin of bank 1A for digital IO if it is assigned to the ADC. However, I currently don't have bank 1A assigned to the ADC - all other channels apart from ANAIN1 are disabled in the modular ADC IP.
My question: is it possible to just use the ADC with ANAIN1 and leave bank 1A set to digital IO? If so, can you help me configure this correctly?
Many thanks!
YuanLi_S_Intel
Broddo
Thanks for the reply. I had missed this in the data sheet. I'll have to rethink my design!
