21615 Discussions
MAX10 ADC sample store with threshold violation detection core
I succesfully followed this example http://www.alterawiki.com/uploads/c/cd/max10_adc_with_threshold_violation_detection_v1.pdf
Now trying to do something "usefull": to turn on a LED when out of thesholds.
I wrote a controller with Avalon ST Sink interface for the threshold related signals and Avalon MM Master interface to write to a PIO Avalon MM Slave. (find attached).
On my board the controller runs a 25MHz system clock, the ADC gets 2MHz from PLL and peform 25KHz sampling. I monitor 4 channels so it should take about 1000 clocks of the controller to expect the sequencer to finish the cycle and decide about threshold violation.
Since I want the LED to stay on while thrshold violated I "latch" the valid signal with a 25bit counter that should give more than a second for another valid to come. It doesn't work!
Can someone take a look at this?
